BrewPi Arduino shield soldering guide for Rev A
This page will give you a step by step guide to soldering your Arduino Shield. I have soldered quite a lot of them and this is the order which I think is the easiest. It is best to keep it close to your soldering iron to make sure you don’t forget something, so here is a QR code to bring it up on your smartphone:
QR Code generator
So lets get started! You will need:
  • A BrewPi Arduino shield kit
  • A soldering iron
  • A tip cleaner (I recommend golden curl over wet sponge)
  • Solder
  • A side cutter
From now on this guide will be nothing but pictures with a description! I think pictures are much more helpful and prevent errors so this guide has a lot of pictures. To help with opening the page on portable devices it is broken up into 5 pages, 15 images per page.
This is what you bought from the shop: a PCB with SMT components soldered and a bag of through hole parts. Go ahead and empty the bag on your desk.
The PCB consists of 3 boards which are connected by mouse bytes. Separate the boards by breaking them.
The PCB consists of 3 boards which are connected by tabs. Separate the boards by breaking them.
Break off the mouse bytes that are left behind.
Break off the tabs that are left behind.
You now have 3 boards: The main shield, the LCD backpack and the rotary encoder breakout board.
These boards will all be connected when you are done.
brewpi-soldering-10
A quick primer on soldering… Step 1: press the tip of your soldering iron against both the pad and the pin.
brewpi-soldering-09
Step 2: Add solder. Do not put solder on your tip first! The flux will evaporate before you start. Push the solder against the pad/pin.
brewpi-soldering-08
Step 3: Wait until the solder flows to the entire pad. You can add a little more solder to help if it doesn’t flow nicely, because this also adds new flux.
brewpi-soldering-07
The result should be a shiny concave joint. If the joint is dull or pointy, the flux has evaporated. Work quicker or lower your soldering temperature.
This picture is just to show you what good solder joints look like: shiny, concave and covering the whole pad. We will get to this board later.
Pages: 1 2 3 4 5 6
15 Comments
  1. Cod on February 18, 2013 at 05:50
    The bottom of page 1,
    “This picture is just to show you what good solder joints look like: shiny, concave and covering the whole pad. We will get to this board later.”
    I think you mean convex 🙂
    I can’t wait to get my hands on one of these units, loving following the progress!
    • Elco on February 18, 2013 at 05:55
      No I am pretty sure I mean concave…
      I quote from this guide:
      Keep the tool against the joint until the solder flows freely throughout the joint. When it flows freely, solder tends
      to form concave shapes between the conductors. With insufficient heat solder does not flow freely; it forms convex shapes—blobs. Once solder shape changes from convex to concave, remove the tool from the joint.
      • James Reedy on February 20, 2013 at 03:47
        The whole of the joint itself is a convex structure COD yes, but in the way Elco uses it here it makes sense. They’re talking about the cross sectional profile of the joint in which case it’s convex. If it were concave it would look bulbous like a mushroom. I too for a moment thought hrmm…concave you say until I considered this interpretation.
        • James Reedy on February 21, 2013 at 01:54
          Boy I really buggered that up and swapped some of the terms. The joint stands off the board = convex, but here the term concave describes the profile of the joint. If it were convex it would be a bulbous ball…the characteristic of a cold solder joint.
      • Gremlyn on February 20, 2013 at 03:49
        I’ll second concave as correct.
  2. John on March 7, 2013 at 20:19
    smooth volcano shape 🙂
    Nice setup ! I`m currently making it … just had to buy a SD card big enough for all the setup. My 4GB was to small. 8GB seems to be ok.
  3. tore on March 10, 2013 at 23:46
    ugh, i soldered the ICP header on the LCD board on the wrong side, and my solder sucker is stuck 🙁 ah well
    • Elco on March 11, 2013 at 00:49
      Been there myself… Any attempt to get it off will probably ruin the connector, so you will have to buy another one. Luckily they are very common. To get it off, you can also make the pin side one big blob of solder, so you can heat all 10 at once.
      You could leave it and assemble the cable in a way that works I think, but it will be very high.
      • tore on March 11, 2013 at 18:37
        Yeah i figured i could just flip the connector and try to bend the header for the LCD to allow for some room to the connector, that or break off some of the plastic around the header and solder wires to the pins and just create a connector out of it that doesnt require so much height.
  4. John on March 11, 2013 at 00:35
    Use a heat gun. Heat it carfully up and give it a little “hit” to the edge of something. With a little practice you can get it out from there. If you use it too much, you will ruin your print… For emergency use only.
    • tore on March 11, 2013 at 18:47
      Dont have a heat gun and im not too keen on ruining the print, im going to try something tommorow and evalute after that.
  5. Wactuary on June 13, 2013 at 03:34
    If you have the new Rev C board, note these instructions are still for the Rev A shield. Elco says the new instructions will be coming soon, but to help folks in the meantime, a few differences to note:
    – There are more pieces in the parts bag – instead of soldering the screw posts to the board as pictured, now you solder terminals and the screwpost plugs will attach to the sensor/actuator wires.
    – If you have an older Uno, there are fewer pins on the arduino than on the shield. Let them overhang the socket by the two pins.
    – There is a 40 pin header in the kit. It’s for the 16 pin space in the LCD. Just cut to size, the extra is a bonus!
    – and not pictured in these instructions is the one-wire distribution board. Self explanatory, once you look closely at it, although if you also got the case, I’m still not quite sure what to do with the one-wire piece of the case kit. But that’s a different matter.
    Good luck!
  6. Julien Mottin on June 13, 2013 at 09:54
    What would be the major diffs between this post and the soldering of parts for revC shield?
    • Wactuary on June 18, 2013 at 04:43
      I tried to outline the major differences in the comment just above yours.
      • Julien on June 18, 2013 at 06:25
        Yes tanks I saw that a bit too late…
        Any way with your comment and the various info from elco I managed to build everything.
        Regarding the case I put the one wire hub on the top of the case at the back and its corresponding pcb on top of it.
        It is convenient then to connect the hub to the one wire port of the arduino and to plug the thermal sensors into the hub.
        Then with the dynaconfig branch everything can be set-up dynamically
        So congrats to all the contributors, the job you have done is really impressive and the level of integration, testing capabilities and look & feel is really high!
